WhatsApp backup restore failing on Android devices managed by HexnodeSolved
4 months ago Aug 03, 2026
A managed Android device is failing while restoring a WhatsApp backup from Google Drive. The error appears during the WhatsApp backup restore flow, and I’m trying to confirm whether a Hexnode policy could be blocking the backup/restore process or if this is more likely an external WhatsApp or Google Drive issue. What Android restriction settings should be checked in Hexnode?
Yes, a Hexnode Android restriction policy can affect backup and sync behavior if certain options are disabled. Check the Android restriction policies associated with the affected device.
In the Hexnode portal, go to:
Policies > select the associated policy > Manage > Modify > Android > Restrictions > Basic Restrictions
Under Allow Sync Settings, make sure Backup service is enabled. If this option is disabled, Android backup and restore services may be blocked on the device.
Also check:
Android > Restrictions > Advanced Restrictions
Under Allow Sync Settings, make sure the following options are enabled:
– Sync data in background
– Sync data with Google account
If multiple Android restriction policies are associated with the device, verify these settings across all of them. A restriction applied from any associated policy can affect the final behavior on the device. After updating the policy, save it and allow the device to sync with Hexnode.
