Webhook Event Triggers missing from Hexnode integrationsSolved
2 months ago Sep 20, 2026
I’m trying to set up real-time automation using webhooks in Hexnode. I found the Integrations section, but I don’t see a Webhooks or Webhook Event Triggers option anywhere. Are webhooks available through the API, or is this tied to a specific plan?
Webhook Event Triggers are supported in Hexnode and can be used for event-driven automation alongside the Hexnode REST APIs. However, the Webhook integrations section is available only on the Ultra Plan.
If the account is on the Pro Plan, the Webhook Event Triggers option will not appear in the Integrations window. An upgrade to the Ultra Plan is required to configure webhook integrations.
For implementation details, refer to the Hexnode Event Triggers documentation for webhook setup and payload structure. For programmatic queries and action execution, refer to the Hexnode API documentation.
That explains it. I’m on the Pro Plan, so I guess that’s why the webhook option is missing. Is there any way to still automate things without enabling webhook event triggers?
If Webhook Event Triggers are not available on the current plan, you can still use the Hexnode REST APIs for supported programmatic actions and queries. The main difference is that webhooks provide real-time event callbacks, while REST API-based automation would typically require your system to query Hexnode periodically or trigger supported actions through API calls.
So, REST API polling can be used as an interim approach for some workflows, but it is not a direct replacement for real-time webhook notifications.
2 months ago Sep 21, 2026
Got it. So the missing webhook section isn’t a UI issue; it’s because the feature is plan-restricted. That clears it up.
