View a daily GPS route report for a device in HexnodeSolved
3 months ago Aug 28, 2026
I need to check the GPS route/location history for a specific managed device in Hexnode, preferably by day. I found the device in the portal but I’m not sure where the route or location report is available. Is there a device-specific report for this, or should I use the general reports section?
Hello @haanaa ,
You can view location data for a specific device from the device details page.
Go to:
  1. Manage > Devices.
  2. Select the required device.
  3. Open the Location History tab.
This section shows the location history recorded for that device and is the best place to check the route/location trail for a single device.
If you want to review location data across multiple devices, go to: Reports > Built-in Reports > Location > Location history.
Use the device-level ‘Location History tab’ when you are checking one specific device, and use ‘Location Reports’ when you need a broader report across the portal.
