I received an email saying an API key was generated in our Hexnode portal, but I didn’t request one. Is this something Hexnode does automatically, or should I treat it as suspicious activity?
Hi @akemi,
This notification is usually expected behavior and does not necessarily indicate suspicious activity.
In Hexnode, an API key can be automatically generated when a technician accesses the Admin > API section of the portal. Since this action does not require a separate manual confirmation step, Hexnode sends an email notification to keep administrators informed.
The notification is sent to the administrators configured in the portal when a technician enables, generates, or accesses the API key section in a way that triggers key generation.
If you received this email unexpectedly, the most likely reason is that another administrator or technician in your organization opened the Admin > API page recently.
