Can Hexnode track the approximate location of both phones and laptops? I’m testing with Android/iOS phones and Windows/macOS laptops. I also wiped a few test devices, but they still show as active under Manage. I tried unenrolling and deleting them, but they don’t seem to disappear from the device list.
Track phone and laptop locations and remove wiped devices in HexnodeSolved
Hi @remy-parker,
Hexnode UEM can track real-time and historical locations for supported Android, iOS, Windows, and macOS devices, provided location services are enabled on the device.
To configure location tracking:
- Go to Policies > Device Policies.
- Create a new custom policy or edit an existing one.
- Select the required platform.
- Navigate to Tracking and Fencing > Location Tracking.
- Click Configure and set Location Update Interval.
- Save and associate the policy with the required devices.
After the device reports location data, you can view it from Manage > Devices > select the device > Location History.
For fleet-level location data, go to Reports > Location >Location History.
That helped. I was initially looking under Policies and only saw Device Policies, Compliance Policies, Templates, and Archived Policies, so the path confused me a bit. Also, for the wiped devices, does wiping remove Hexnode from the device?
Yes. A wipe resets the device and removes the management profile and managed apps, including the Hexnode UEM app where applicable. Once that happens, the device can no longer communicate with the Hexnode server to update its status automatically.
For wiped devices that remain listed as active, use this cleanup workflow:
- Go to Manage > Devices.
- Select the wiped device.
- Click Actions > Device Control > Disenroll Device.
- Once disenrollment is initiated, open Actions again.
- Select Mark as Disenrolled.
After marking the device as disenrolled, it will be removed from the active device list under Manage.
