Stop Waiting and Start Deploying: Remote File Deployment for Windows is Live!Solved
3 months ago Jul 28, 2026
Say goodbye to clunky scripts, manual transfers, and flash drive gymnastics! We are absolutely thrilled to unveil one of our most requested features: Remote File Deployment for Windows devices.
Managing your Windows fleet just got a whole lot more powerful. You can now leverage the Hexnode file repository to deploy files directly to the exact folders they need to be in on your Windows endpoints, entirely over-the-air.
Key Capabilities
  • Direct Repo-to-Device Deployment: Select any file, script, or document right from the Hexnode file repository and blast it straight to your Windows fleet.
  • Pinpoint Precision Delivery: You are in the driver’s seat. Specify the exact local directory path on the target device, and Hexnode will drop the file right where it belongs—no user intervention required.
  • Silent, Over-The-Air Magic: Push files flawlessly in the background. Whether you are targeting a single rogue laptop or deploying to ten thousand workstations at once, your end-users won’t even know it happened.
Why remote file deployment is a game-changer?
Remote file deployment isn’t just a feature; it’s a massive time-saver. Need to push a critical custom .xml config, drop a fresh batch of corporate wallpapers, or distribute an internal .exe installer? You can now do it all from a single pane of glass in record time.
The Bottom Line: Less time wrestling with workarounds means more time focusing on what really matters—scaling and securing your enterprise.
You can check out our help documentation to know more about remote file deployment.
So, what are you waiting for? Head over to your Hexnode portal to take it for a spin!
