Multiple Remote Session: All Your Remote Sessions on One ScreenSolved
3 months ago Sep 09, 2026
Technicians have long been able to run remote sessions for multiple devices on Hexnode UEM—just not simultaneously at the same place. Each remote session of a device required opening the portal in a new browser tab, meaning constant switching to keep track of everything.
That changes with the Multiple Remote Session remote action. Instead of juggling tabs, technicians can now launch a single remote action that pulls up and displays the remote sessions of multiple selected devices together, side by side, and from a single screen — all running simultaneously.
How it Works
  • Go to the Manage tab.
  • Select the devices you want to connect to.
  • From the Actions dropdown, choose Multiple Remote Session.
  • Each selected device’s remote session opens in its own window, displayed together for easy monitoring and control.
Why it matters
  • One window, full visibility: See all connected devices at once instead of flipping between browser tabs.
  • Faster troubleshooting: Spot issues and compare device states in real time, side by side.
  • No limit on concurrent sessions: Connect to as many devices as you need, all within the same view.
Whether you’re rolling out a fix across multiple machines or keeping an eye on several devices during a troubleshooting session, Multiple Remote Session helps your team move faster and work smarter. Ready to see it in action? Head over to your Hexnode UEM portal and try it out today!
