Samsung Android 15+ – Black Display During Remote View of Sensitive ContentSolved
1 month ago Oct 08, 2026
While I was using Hexnode Remote View to troubleshoot a Samsung device running Android 15, the screen turns black specifically when password entries, PIN prompts, or secure login screens appear.
Why is this happening?
Hi,
This behavior typically happens on Samsung devices running Android 15 or later due to built-in screen-share protection, which prevents sensitive content from being displayed to remote viewers.
Password fields, PIN prompts, and other sensitive content may therefore be hidden from remote viewers even though the content is displayed normally on the physical device.
To resolve this issue, disable the screen-share protection from the Samsung device’s Developer options. Before doing so, make sure the required settings are enabled in the Hexnode UEM policy associated with the device.
Step 1: Check the Hexnode UEM Policy
  1. Make sure Screen Capture and Developer Mode are enabled in the Hexnode UEM policy associated with the device. To verify this:
  2. Navigate to Hexnode UEM > Policies.
  3. Select policy associated with the Android device.
  4. Navigate to Advanced Restrictions.
  5. Check whether Screen Capture and Developer Mode are enabled. If either setting is disabled, enable it and save the policy.
Step 2: Enable Developer Options on the Samsung device
  1. Open Settings on the Samsung device.
  2. Go to About phone and select Software information.
  3. Locate Build number and tap on it 5 times.
A message indicating that Developer Options have been enabled should appear.
Step 3: Disable screen-share protection
On the Samsung device:
  1. Open Settings > Developer options.
  2. Locate the screen-sharing protection setting.
  3. Depending on the Samsung software version, the option may be displayed as Disable screen share protection or Turn off screen share protection.
  4. Turn on the option to disable screen-share protection.
 Once the required settings are configured, start a new Remote View session in Hexnode UEM portal to verify whether the affected screen is displayed correctly.
If you continue to experience the issue or face any other difficulties, feel free to reach out to us.
William Blake
I followed these steps and enabled Disable screen share protection in Developer Options. The login screen is now visible through Remote View.
Does this mean that all black screens caused by Android 15 can be resolved by disabling this setting?
@r_foster
The issue may still occur if the black screen is caused by the application itself.
Some applications use Android’s FLAG_SECURE mechanism to prevent sensitive content from being captured or displayed through screenshots, screen recording, casting, or remote viewing.
Disabling Samsung’s screen-share protection does not guarantee that application–level FLAG_SECURE restrictions will be bypassed.
The result depends on what is causing the black screen:
  • If the black screen is caused by Samsung’s screen-share protection, disabling the relevant screen-share protection can resolve the issue.
  • If the application uses FLAG_SECURE or another capture restriction, the content may continue to appear black.
William Blake
