I want to remove one Hexnode policy from multiple users/devices. What is the correct way to remove it from selected devices, or from all devices if needed?
Remove a directly assigned Hexnode policy from multiple devicesSolved
Tags
Hey @sophia_miller,
If the policy was assigned through a device group, remove the device from the policy scope by excluding it from that group.
- For a device group-based policy
- Go to Manage and open the device.
- Open Device Info and copy a unique identifier such as the Serial Number or UDID.
- Go to Manage > Device Groups and open the relevant device group.
- Open Criteria and select Add Exception.
- Configure the exception, for example:
- Group: Device Info
- Column: Serial Number
- Comparator: Is
- Filter: Paste the copied serial number
This prevents that device from being included in the dynamic device group and removes policies that are applied through that group.
- If the policy was applied directly to devices instead, use the policy target settings:
- Go to Policies.
- Open the policy you want to remove.
- Click Manage in the top-right corner.
- Select Modify > Policy Targets.
- Remove the devices, users, or groups that should no longer receive the policy.
- Save the policy.
You can confirm how the policy is applied by opening Manage >
I was looking at the device group first, but on the device’s Policies tab the policy shows as directly applied. So in that case I should not add a group exception, right?
Correct. A device group exception only helps when the policy reaches the device through that specific device group. If the policy is assigned directly, editing the group criteria will not remove it.
