macOS Blocklist/Allowlist policy fails with “Action not supported” on older enrolled MacsSolved
5 months ago Jun 01, 2026
We have a macOS Blocklisting/Allowlisting policy configured for Blocklist Apps and assigned to all Mac devices through a dynamic device group. New MacBooks enrolled after the policy was created get the profile successfully, but older enrolled MacBooks show the policy as Failed in Action History.
The failed devices show an “action not supported” type error, while newly enrolled devices receive the same Effective Profile without any issue. We also tried assigning the policy directly to affected devices, but the older Macs still failed.
Has anyone seen macOS app blocklist policies behave differently based on when the device was enrolled?
Hi @lucaas,
This can happen if the final effective configuration being deployed to the Mac differs between devices, even when the same policy appears to be assigned. For macOS Blocklisting/Allowlisting policies, check the following on an affected device:
  1. Confirm whether the policy is assigned only through the intended dynamic device group, or whether it is also directly associated with the device or user.
  2. Check for any other app blocklist/allowlist policies targeting the same Mac through another group, user assignment, or test policy.
  3. Remove conflicting or duplicate policies if the same restriction is being applied from multiple sources.
  4. Reapply the Blocklist Apps policy after cleaning up the assignments.
  5. Compare the Action History status again after the effective profile is regenerated.
If the policy works for newly enrolled Macs but fails only on older enrolled Macs, also test the same blocklist policy with another known macOS app. That helps confirm whether the failure is caused by the policy deployment in general or by a specific app entry in the blocklist.
I’ve run into something similar with app restriction policies where direct assignment plus group assignment made troubleshooting confusing. The device page showed the policy, but the effective profile wasn’t always what we expected until we removed the extra assignment and deployed the policy again.
