MacBook locked by remote lockSolved
6 months ago May 01, 2026
Hi everyone, we’re currently locked out of a MacBook after issuing a remote lock from Hexnode. The device is asking for a 6-digit PIN, but the one we set isn’t working.
We even tried sending another lock command with a new PIN, thinking it might override the old one, but that didn’t help either. Has anyone faced something similar?
6 months ago May 02, 2026
Yeah, we ran into this once. At first, we thought the PIN didn’t go through properly, but it turned out the device was still expecting the original one. Did you double-check what was actually sent from the console?
6 months ago May 03, 2026
We used the PIN we entered during the lock command, but didn’t verify it afterward. Is there a way to confirm that?
Hi @roger,
This usually happens when there’s a mismatch between the PIN you intended to send and the one that was actually registered by the device.
When a remote lock is triggered, the PIN from that initial command is what gets stored on the device. Even if you send another lock command later, the device won’t switch to a new PIN until it’s unlocked first.
You can verify the exact PIN by checking the Action History in the portal. That will show you the actual code that was transmitted during the first lock.
Additional Troubleshooting Tips:
  • Check for Special Keys: Ensure Caps Lock is off, as it can occasionally interfere with how the PIN is registered.
  • Keyboard Layout: If the PIN was set on a machine with a different regional keyboard layout (e.g., UK vs. US), certain characters or the layout might be shifted. Double-check if the keys you are pressing match the intended input.
  • External Keyboards: If you are using a Bluetooth keyboard, it may not be paired or active at this lock screen. Please use the built-in MacBook keyboard to enter the PIN.
6 months ago May 04, 2026
Just to add to that, we made the mistake of assuming the second PIN would replace the first one. It doesn’t work that way. The device basically ignores any new PIN attempts until it’s unlocked with the original.
Got it, thanks everyone. This makes a lot more sense now.
