Linux device marked non-compliant due to inactivity despite being in useSolved
4 hours ago Nov 30, 2026
One of our Linux devices was marked non-compliant because of 8 days of inactivity, but the employee is actively using the machine. We also noticed an older local user account on the device and tried removing it, but the action stayed pending.
Does Hexnode mark a device inactive because a local user account is unused or disabled? What is the safest way to make the device compliant again?
9 minutes ago Nov 30, 2026
Device inactivity in Hexnode is based on agent check-ins, not local user activity.
An inactive or unused local user account does not make the entire device inactive or non-compliant. Hexnode marks a device inactive when the Hexnode agent on the device does not check in with the portal within the inactivity threshold configured under Admin > General Settings > Inactivity Settings.
Common causes include:
  • The device was powered off, asleep, or hibernating for an extended period.
  • Internet access was unavailable or blocked by a firewall/VPN.
  • The Hexnode agent service was stopped, corrupted, or removed from the device.
If the device is actively used but still appears inactive in the portal, the most likely cause is that the Hexnode agent is not reporting correctly. Re-enrolling the device can restore the agent connection and allow the device to sync compliance status again.
