iPad not appearing in managed devices after AB integrationSolved
6 months ago May 21, 2026
Hi team,
I’m having some trouble with a new iPad. I’ve successfully added the device to our Apple Business account, but for some reason, it isn’t showing up under the Devices tab in my Hexnode portal.
Am I missing a step in the sync process?
Replies (6)
Hey @carter! It sounds like the device is in the system but hasn’t fully “checked in” with the MDM side of the portal yet.
First, let’s make sure the sync is up to date. Please try the following:
  1. Navigate to Admin > Apple Business/School Manager.
  1. Go to Automated Device Enrollment > Accounts.
  1. Click on Sync all ADE accounts.
Once that’s done, check if the device appears under Automated Device Enrollment > Devices. Let me know what the Profile Status says for that iPad.
6 months ago May 22, 2026
Okay, the sync worked! I can see the iPad in that list now.
The profile status is currently showing as “Assigned.” However, it still isn’t appearing in my main managed devices list. How do I move it forward from here?
Thanks for checking! If the status is “Assigned,” it means Hexnode has associated the enrollment profile with the device’s serial number in the cloud, but the iPad itself hasn’t “downloaded” those instructions yet.
To trigger the actual enrollment:
  1. Factory Reset the iPad.
  1. During the initial “Hello” setup screens, ensure it is connected to Wi-Fi.
  1. You should see a Remote Management screen appear. This is the device recognizing the Hexnode assignment.
Once you accept the Remote Management prompt, the status will change to “Pushed“, and the device will finally appear in your main Manage > Devices tab.
I actually just performed a reset to get it into Apple Business via Apple Configurator. Do I really need to reset it again now that it’s in the portal?
Also, once it reboots, do I need to scan a Hexnode QR code to finish it off?
Yes, a second reset is necessary. The device only “looks” for an MDM assignment from Apple’s servers during that initial setup phase. Since the assignment happened in the portal after your last reset, the iPad won’t know it’s managed until it goes through the activation process again.
As for the QR code: No need! Since this is an ADE (formerly DEP) enrollment, the process is automatic. Just proceed past the “Hello” screen and follow the on-screen prompts. When you hit the Remote Management screen, just click “Next” or “Enroll,” and you’re good to go!
Perfect, that makes total sense. Running the reset now. Thanks for the help!
