iOS VPP app stuck at Initiated for one device in HexnodeSolved
5 days ago Nov 16, 2026
One iPhone started communicating with Hexnode again after updating iOS, but WhatsApp deployment is now stuck. The app is assigned through an iOS Required Apps policy and the action history stays at “Initiated” / “In progress”.
The device has internet access, has been restarted, and VPP sync completed. There are enough Apple VPP licenses available. Other VPP apps install on this same iPhone without issues, and WhatsApp installs fine on other iPhones. It seems to be isolated to this one device and this one app.
Is there a way to clear the stuck WhatsApp deployment without wiping the device?
Hi @jimena ,
Since the issue is limited to one VPP app on one iOS device, while other VPP apps install correctly on the same device and the same app installs correctly on other devices, this usually points to a stalled VPP license assignment or a stuck deployment task for that device.
Try revoking and reassigning the VPP license for the affected app:
  1. Go to Admin > Apple Business/School Manager > Apple VPP.
  2. Select the Apple VPP account used for app deployment.
  3. Run a VPP sync.
  4. Open the Apps tab and locate WhatsApp.
  5. Go to the license details for the app.
  6. Revoke the license assigned to the affected device or user.
  7. Reassign the license to the same device or user.
  8. Go to Manage > select the iOS device > Actions > Scanning & Monitoring > Scan Device.
After this, the existing stalled installation state should clear and the Required Apps policy can push the app again.
Just to confirm, native iOS apps like Contacts do not need to be added as mandatory apps, right? I noticed that removing Contacts from the policy did not affect the WhatsApp issue.
