How to delete a local user from the Hexnode UEM consoleSolved
2 months ago Oct 06, 2026
I’m trying to remove a local/device user from the Hexnode console. I can find the user under Users, but I’m not seeing a clear delete option. Is there a specific place where the Delete User action appears, and does it work differently for local users and domain users?
Hi @remi,
For a local/device user, the delete option is available from the user list after selecting the user.
Steps:
  1. Go to Manage > Users in the Hexnode console.
  2. Search for the local user you want to remove.
  3. Select the checkbox next to the username.
  4. Click the Actions > Edit dropdown at the top of the table.
  5. Select Delete User and confirm the prompt.
These steps apply to local users. If the user has devices assigned, reassign or disassociate those devices before deleting the user. This helps avoid leaving device assignments linked to a user record that no longer exists. If the account is a domain-synced user, make sure you are checking the correct user section, as the deletion workflow can differ depending on how the user was added.
