How can we enforce role-based access using geofencing and AD attributes in Hexnode?Solved
5 months ago May 01, 2026
Hey everyone,
We were setting up corporate devices for our IT team and ran into a bit of a design challenge. We wanted certain roles (like system admins) to have elevated access only when they’re physically inside our data center.Initially, we tried static grouping, but it quickly became messy when people changed roles or moved between locations.
Is there a way in Hexnode to dynamically control access based on both user role (from AD) and their physical location? Ideally something that updates automatically without us having to constantly reassign devices.
Thanks for raising this query!
What you’re trying to achieve is absolutely possible using Hexnode’s dual-group dynamic workflow, which combines directory attributes with geofencing.
Instead of relying on static assignments, you can build logic around two continuously evaluated conditions:
  • The user’s role (synced from AD/IdP, such as Title or Office Location)
  • The device’s real-time location (via geofences)
Here’s how this works in practice:
You create a geofence that represents your authorized location (for example, your data center). Then, you define two dynamic device groups:
  1. An “Inside” group that includes devices when:
  • The user matches a specific AD attribute (e.g., Title = Senior System Administrator)
  • AND the device is inside the geofence
  1. An “Outside” group that includes the same users but when:
  • The device is outside that geofence
This creates a clean “if/then” transition model. As the user moves in or out of the defined boundary, their device automatically shifts between these groups.
You can then associate:
  • A high-privilege policy with the Inside group (e.g., admin tools, internal access)
  • A restricted policy with the Outside group (e.g., blocklisted tools, tighter controls)
The key advantage here is that everything is identity-aware and self-updating. If HR updates a user’s role in AD, the next directory sync ensures that the correct policies apply without manual intervention.
Please do reach out if you have more queries.
