Expired APNs certificate: macOS devices stuck on “disenrollment initiated”Solved
3 months ago Sep 10, 2026
Our APNs certificate expired, so I removed the old APNs setup and started configuring a new one. Before doing that, I tried to disenroll all macOS devices, but they are still stuck at “disenrollment initiated”. Even a Mac that is online does not seem to receive the command.
When I click Finish during the new APNs setup, nothing really happens. Is this because there is no active Apple Push certificate to deliver the disenroll command? Also, what should be done for Macs that are not physically available right now?
Yes @ruthg_
If the APNs certificate has already expired, Hexnode cannot deliver remote MDM commands to Apple devices through APNs. This includes remote disenrollment commands.
In this state, devices may remain in “disenrollment initiated” in the portal because the command cannot reach the device. Removing the old APNs certificate from the portal lets you configure a new APNs certificate, but it does not remove the old MDM profile from the device itself.
For devices you can access physically or through the end user, remove the old MDM profile manually first:
System Settings > Profiles, then remove the old MDM profile.
After the old profile is removed, enroll the device again using the new enrollment link or QR code associated with the new APNs certificate.
What about a Mac that is with an employee who is away for a few weeks? Can I just delete it from the Hexnode console and enroll it again later?
You can clean up the device entry in the Hexnode portal by marking the device as disenrolled:
Manage > Devices > select the device > Actions > Mark device as disenrolled
This only updates the device status in the portal. Since the APNs certificate is expired, Hexnode still cannot send a command to the Mac to remove the MDM profile from the device. The old profile will remain installed on the Mac until the user manually removes it.
When the device becomes available again, the user should remove the old MDM profile from System Settings > Profiles and then enroll again using the new enrollment link.
What if the device is marked as disenrolled in the portal but the old profile is still on the Mac, can the user install the new enrollment profile anyway?
No. Apple allows only one active MDM profile on a macOS device at a time.
If the old MDM profile is still installed and the user tries to install the new enrollment profile, the installation will fail because an MDM payload is already present on the device.
The correct order is:
  1. Remove the old MDM profile from the device.
  2. Install the new enrollment profile.
  3. Complete enrollment under the new APNs certificate.
For devices enrolled through Apple Business or Automated Device Enrollment, a factory reset will remove the old profile and apply the assigned MDM profile again during the device setup process.
