Enterprise Android APK not updating via policy after manual installSolved
4 hours ago Nov 23, 2026
I’m trying to deploy a new version of an enterprise Android app through Hexnode, but the policy does not seem to push the updated APK to the device.
The older version of the app was installed manually on one Android device. For the new version, I uploaded the latest APK as a new separate app entry in the Apps tab and assigned it through an app policy. The app is still not getting deployed or updated on the device.
Does Hexnode treat the new APK as an update automatically, or is there a different way to update enterprise Android apps?
26 minutes ago Nov 23, 2026
For enterprise Android app updates, the updated APK should be uploaded by editing the original app entry rather than adding it as a separate app.
When the new APK is added as a separate app entry, Hexnode treats it as a different app object in the portal. Even if the APK has the same package name, this does not work the same way as replacing the APK in the already assigned enterprise app entry.
Also, since the older version was installed manually on the device, the MDM deployment may not be able to overwrite it cleanly. Android can block the installation if there is a package signature mismatch, an incompatible version, or if the installed app is not managed through the same deployment flow.
Recommended steps:
  1. Go to Apps in the Hexnode UEM portal.
  2. Open the original enterprise app entry.
  3. Edit the app and replace the old APK with the new APK file.
  4. Save the app.
  5. On the Android device where the app was installed manually, uninstall the manually installed version.
  6. Assign the original app through Policies > Required Apps.
Once the Required Apps policy is applied, Hexnode will deploy the updated APK to the assigned Android devices.
