Enable MFA with a third-party authenticator app for Hexnode techniciansSolved
2 months ago Oct 10, 2026
Is it possible to use MFA for Hexnode admin or technician login with an authenticator app instead of email verification? I’d like to switch to a third-party authenticator if Hexnode supports it.
Hi @josiah,
Hexnode supports MFA for admin and technician accounts using standard third-party authenticator apps.
To require a technician to set up an authenticator app:
  1. On the Hexnode UEM console, navigate to Admin > Technicians and Roles > Profile.
  2. Create or edit a technician profile.
  3. Enable the option to ask the user to set up a third-party app for MFA.
  4. Assign the required scope or permissions to the profile.
  5. Go back to the technician list and edit the technician account.
  6. Under Assign profile, select the profile you created and save the changes.
After the profile is assigned, the technician will be prompted to configure MFA with a supported authenticator app during login or setup.
