Enable IP-based location tracking for macOS devices when Location Services is disabledSolved
5 months ago Jun 25, 2026
Some of our managed macOS laptops show location history in Hexnode, but others do not. A Location policy is already configured, but I’m trying to make sure location history is always available where possible. Is there a way to enforce this on Macs, especially if users turn off Location Services?
On macOS, location reporting that depends on Apple’s local Location Services can be affected by user permissions and system-level privacy restrictions. If Location Services is disabled on the Mac, precise location data may not be available through the usual macOS location framework.
For this scenario, enable IP-Based Tracking in the Location policy. IP-Based Tracking does not rely on the Mac’s local Location Services, GPS, or Wi-Fi triangulation. Instead, Hexnode estimates the device location using the public IP address used by the Mac when it checks in with the Hexnode server.
This means:
  • Location can still be reported even if the user disables Location Services on the Mac.
  • The device must be connected to the internet and checking in with Hexnode.
  • The reported location will be approximate, since it is based on public IP geolocation.
If rough location is sufficient for your use case, IP-Based Tracking is the recommended option for improving location availability across macOS devices.
5 months ago Jun 26, 2026
That makes sense. We don’t need exact GPS-level location, just a general idea of where the laptops are. I enabled IP-Based Tracking and will monitor the devices after they check in again.
