Drowning in a massive policy file – time to break it up?Solved
10 months ago Jan 21, 2026
Hey everyone, I’m hoping someone can save my sanity. I manage a growing fleet of devices for a logistics firm, and right now, I have absolutely everything—Wi-Fi credentials, app configurations, kiosk settings, and security restrictions—crammed into one giant monolithic policy.
It was totally fine when we only had about 50 tablets, but now we are scaling into the hundreds across multiple departments. Tweak one Wi-Fi password for the warehouse, and I’m suddenly pushing this massive update to every single device. Should I be breaking these up into separate, modular policies? Specifically, I’m curious how a modular approach actually affects deployment speed and the flexibility of moving devices around when an employee shifts from the warehouse to the front office. Would love to hear from anyone who has made this transition!
When you use a monolithic policy, updating one tiny detail means you are forcing the device to redownload and apply the entire heavy payload all over again. In my experience, that occasionally led to longer sync times or devices timing out. With a modular approach, you deploy specific updates. If you change a password in your Warehouse Wi-Fi Policy, it only sends that tiny configuration packet. It’s incredibly fast and light.
As for flexibility, it makes life so much easier. If a tablet moves from the warehouse to the office, you don’t need to build a brand new 50-setting monolithic policy for that specific scenario. You just unassign the warehouse app policy and assign the office one. It gives you an agile, building-block approach to management.
10 months ago Jan 22, 2026
I do worry before I spend my weekend tearing down my entire setup, though. If I break things down and suddenly have five different policies applied to one device group (like a base security policy, a Wi-Fi policy, an app policy, and a department-specific restriction policy), doesn’t troubleshooting become a nightmare? What happens if two of those policies conflict? Let’s say my base security policy allows the camera, but the warehouse restriction policy blocks it. How does the system handle that, and how do I figure out what’s breaking if a user complains?
10 months ago Jan 24, 2026
If a restriction fails in your current monolithic setup, finding the culprit inside a massive list of settings is like looking for a needle in a haystack. With modular policies, if a device isn’t connecting to the network, you know exactly which policy to inspect.
Regarding conflicts, Hexnode follows a most restrictive logic. In your camera example, if Policy A says allow and Policy B says restrict, the device will default to restricting the camera. It always prioritizes security.
Once you know that rule, you can actually use it to your advantage by layering your security. You can deploy a baseline policy for everyone, and then stack stricter modular policies on top depending on the department’s needs. My advice? Don’t tear it all down at once. Start by peeling off just your Wi-Fi settings into a separate policy, see how smooth the deployment is, and go from there!
