Disable pull-to-refresh in Hexnode Browser on Android kiosk devicesSolved
2 months ago Oct 04, 2026
Is there a way to stop users from manually refreshing a page in Hexnode Browser on Android kiosk devices? We’re using the browser in kiosk mode and users can refresh the page by pulling/swiping down. The goal is to prevent accidental manual refreshes and allow the page to reload only through the web app’s own programmatic logic.
Hi @remy-parker,
If the manual refresh is happening through the pull-down gesture in Hexnode Browser, it can be disabled from the Android kiosk policy.
Configure it as follows:
  1. On the Hexnode UEM portal, navigate to Policies and open the kiosk policy applied to the Android devices.
  2. Navigate to Kiosk Lockdown > Android Kiosk Lockdown > Advanced Kiosk Settings.
  3. Scroll to Other Settings.
  4. Disable Pull-down to refresh the web page.
  5. Save the policy and sync it with the devices.
Once the updated policy reaches the devices, users will no longer be able to refresh the web page using the pull-down gesture in Hexnode Browser. Any reloads triggered by the web page or application logic can continue to work independently.
I saw an option for scheduled reload under advanced kiosk settings too. Is that the same thing, or does it just reload the page at intervals?
Hi @remy-parker,
Scheduled reload and pull-down refresh control different behaviors.
– Pull-down to refresh the web page controls whether users can manually refresh the current page using the swipe/pull-down gesture.
– Scheduled reload reloads the kiosk browser page automatically at configured intervals.
If the requirement is to stop accidental manual refreshes, disable Pull-down to refresh the web page. Use scheduled reload only if you also want Hexnode to refresh the page automatically on a timer.
