Deploying WireGuard on macOS with Hexnode requires Apple Business Manager VPP licensesSolved
1 month ago Jul 21, 2026
I added the WireGuard app under Local Apps in Hexnode and was trying to push it to macOS devices, but I could not find a way to install it on the Macs from there. Is WireGuard installable on macOS through Hexnode as a local app, or does it need to be added another way?
To deploy WireGuard to macOS devices through Hexnode:
1. Sign in to Apple Business.
2. Go to Apps and Services and open the app store section.
3. Search for WireGuard.
4. Under Buy Licenses, enter the required quantity and select Get.
5. In the Hexnode portal, go to Admin > Apple Business/School > Apple VPP.
6. Click Sync to sync the newly purchased app licenses.
7. After the sync completes, go to the Apps tab and confirm that WireGuard appears with available VPP licenses.
8. Add the app to a policy under Required Apps and associate the policy with the required macOS devices.
If WireGuard is only added as a Local App, it will not be deployed to macOS devices as a Mac App Store app. The VPP version from Apple Business Manager is required for this deployment workflow.
