Yes. Hexnode supports Android app notification management.
You can configure app notification settings so that only selected apps are allowed to send notifications on managed Android devices. Apps that are not allowed can be restricted from showing notifications, while the apps themselves can remain installed and usable.
Hexnode can also track notification trigger counts per app, which helps identify apps that generate frequent notifications.
A typical setup would be:
- Create or edit an Android policy in Hexnode UEM.
- Configure the App Notifications settings.
- Add the apps that should be allowed to send notifications.
- Save the policy and associate it with the required Android devices or device groups.
- Use the notification monitoring data to review per-app notification trigger counts.
This is useful when you want to keep only business-critical alerts visible while suppressing unnecessary app notifications.
