Can I use an Outlook email for Android Enterprise binding in Hexnode?Solved
3 months ago Aug 07, 2026
I’m setting up a test Hexnode portal and want to enroll Android devices using Android Enterprise. During the setup, it asks for account/domain-related details. My current Hexnode portal login uses an Outlook email address. Can I use that same email for Android Enterprise, or does the account need to be unique?
Hi @juan_garcia,
For Android Enterprise setup in Hexnode, the account used for binding must be a Google account.
If your current Hexnode portal login is an Outlook or other non-Google email address, you cannot use that exact email directly to create the Android Enterprise binding. You should create or use a dedicated Google account for managing the Android Enterprise setup.
Best practice is to use a Google account that is meant specifically for device management rather than a personal account. This helps avoid access issues later if the person who created the binding leaves the organization or no longer manages the portal.
That makes sense. This is only a test portal for validating the setup before creating the actual customer portal, so I’ll create a separate Google account for the Android Enterprise binding.
We do the same for demo and customer portals. Keeping a separate Google account for each Android Enterprise binding makes it much easier to track ownership and avoid mixing test and production enrollments
For a test or trial portal, using a dedicated Google account is the right approach. When you later create the production portal, bind Android Enterprise there with the Google account intended for that customer or organization.
Avoid reusing a non-Google portal login email for Android Enterprise enrollment, and avoid using the same management account across unrelated customer environments unless that is part of your organization’s intended management model.
