Can Hexnode schedule Android app launches every hour?Solved
4 months ago Jul 04, 2026
I’m testing Remote App Launch on Android devices through Hexnode Automations. I created an Android automation and selected the app launch option, but the scheduling screen only seems to let me run it daily, weekly, or monthly.
Is there a way to launch an app every hour instead of once per day? I don’t want to create a daily schedule if the app needs to relaunch hourly.
Hi @sebastin,
Hexnode’s Android Remote App Launch automation currently supports scheduling based on daily, weekly, or monthly recurrence.
Hourly scheduling is not available for the Remote App Launch action at this time. You can configure the app launch automation by going to: Automations > Android > New Automation > App Management > Remote App Launch
Then select the app, configure the available schedule, choose the target device group, and save the automation.
If your requirement is to launch the app every hour, that exact interval is currently a product limitation. The best available option is to use one of the supported recurrence intervals. Hourly app launch scheduling can be treated as a feature request for future enhancement.
