Hello @amy_taylor ,
Hexnode UEM can report installed application inventory, including details such as app names, versions, and bundle identifiers where supported by the platform. However, Hexnode UEM cannot determine whether MFA is enabled inside individual third-party applications.
This is due to OS-level sandboxing and privacy restrictions. MDM solutions do not have access to an app’s internal user-specific settings, authentication state, login method, or MFA configuration.
To verify and audit MFA enforcement, use the Identity Provider or SSO platform that handles authentication for those apps, such as Microsoft Entra ID, Okta, or Google Workspace. If the apps are federated through an IdP, the IdP admin console and sign-in logs are the correct place to confirm MFA enforcement and review authentication activity.
Hexnode UEM can still help with the device-management side by deploying the apps and, where the app supports it, pushing Managed App Configurations to direct users to the organization’s SSO flow. The actual visibility into MFA status remains with the identity provider.
