Can Hexnode purchase or push eSIM profiles to Android 14 devices?Solved
4 months ago Jul 14, 2026
Is it possible to use Hexnode to purchase eSIM plans and push eSIM profiles to Android 14 devices? We are looking at managing cellular connectivity for a group of Android devices and wanted to know if Hexnode can handle the eSIM deployment directly.
Hello @amy_taylor ,
Hexnode UEM does not provide or sell cellular data plans or eSIM profiles. eSIM subscriptions must be purchased directly from a cellular carrier or telecom provider.
For deployment, Hexnode currently supports pushing eSIM configurations only for iOS devices. Pushing eSIM profiles to Android devices, including Android 14 devices, is not supported at this time.
If you need eSIM management for Android, the eSIM profile provisioning would need to be handled outside Hexnode through the carrier-supported method available for your devices.
