Can Hexnode detect rooted Android or jailbroken iOS devices?Solved
7 months ago May 01, 2026
Hi everyone, I need to find a way to detect rooted Android or jailbroken iOS devices using Hexnode. Is that possible?
We just add “rooted” as a column in the Manage tab to check if a device is rooted. Alternatively, you can create dynamic groups to automatically group devices that are rooted or jailbroken.
7 months ago May 02, 2026
Thanks, that makes sense. But can this also be used for compliance visibility?
Hi @noah-blake,
You can achieve this by setting up compliance policies in Hexnode to mark such devices as non-compliant. Here’s how you can configure it:
  1. Go to Policies > Compliance Policies > New Policy in your Hexnode UEM portal.
  2. Select the appropriate device platform (Android or iOS).
  3. Provide a policy name and an optional description.
  4. Navigate to Advanced Settings > Configure.
  5. For Android:
    • Set the condition to mark devices as non-compliant if:
      • Column: Device root status
      • Comparator: Is
      • Value: Rooted
    For iOS:
      • Column: Jailbreak
      • Comparator: Is
      • Value: Enabled
  6. Associate the policy with the target devices.
Once applied, devices that are rooted or jailbroken will automatically be marked as non-compliant, and this status will be reflected on the device end as well.
