Blank “Authenticate to Continue” prompt when deleting files in Hexnode Content LibrarySolved
2 weeks ago Nov 05, 2026
I’m trying to delete an uploaded file from the Hexnode Content area, but when I select delete, an “Authenticate to Continue” pop-up appears with no fields or buttons in it. It’s just a blank authentication prompt, so I can’t proceed with deleting the file from Content > Library. Has anyone seen this before?
Hi @thomas_m ,
This can happen if the re-authentication modal does not load correctly in the browser session.
Start by ruling out local browser causes:
  1. Sign out of the Hexnode UEM portal and sign back in.
  2. Clear browser cache and cookies.
  3. Try the same action in a private/incognito window.
  4. Test from another supported browser.
  5. Temporarily disable browser extensions that may block scripts or embedded prompts.
Then try deleting the file again from Content > Library.
I tried incognito mode, cleared browsing history/cache/cookies, disabled extensions, and logged back in. The issue is still exactly the same when deleting from Content > Library. The Documents workaround does let me delete the file though.
For MSP-associated portals, this behavior was linked to the way password re-authentication is handled. Password confirmation is normally bypassed in those portals, but file deletion from Content > Library was still trying to call the re-authentication modal. Because the modal was not applicable in that portal context, it could appear blank.
The workaround is correct:
Content > Kiosk File Shortcuts > Documents > select the file > Delete
A portal-side update has since been rolled out so file deletion in Content > Library follows the same MSP portal behavior and skips the unnecessary password re-authentication step. Refresh the browser or log out and back in, then try deleting the file again from Content > Library.
