Hi @akemi,
This can happen when the Apple Account used for APNs has more than one push certificate associated with it, or when the same Apple Account is used across multiple Hexnode portals/accounts.
To confirm which certificate the alert refers to:
- Log in to the Apple Push Certificates Portal with the Apple Account used for APNs.
- Click the Info icon next to each listed certificate and check its UID.
- In Hexnode, go to Admin > APNs and check the Topic/UID of the APNs certificate configured there.
- Compare the UID in Hexnode with the certificates listed in the Apple portal.
- If you manage multiple Hexnode portals, repeat the check in each portal.
If the UID in your main Hexnode portal matches the certificate that is valid until next year, the alert is most likely for another APNs certificate or another Hexnode portal using the same Apple Account.
