Anyone else sweating over Gemini data privacy and the new Android Auto features?Solved
6 months ago May 14, 2026
Hey folks! Just finished catching up on the Android I/O 2026 recap page (https://www.android.com/new-features-on-android/io-2026/) and I’m equal parts hyped and stressed. From an IT admin perspective, I’m kind of panicking. With Gemini proactively handling busy work and pulling context across the entire device, how do we stop it from accessing sensitive corporate data? We heavily rely on Android Enterprise Work Profiles, and I’m really worried this new AI is going to cross over and read our internal company emails or docs to generate its smart suggestions. Has anyone looked into how the native Android management APIs handle this without completely nerfing the devices?
Hey! The whole Gemini understands your vibe thing is super cool right up until it starts understanding your company’s NDA documents, right? I’ve actually been testing the Android 16 developer preview, and the good news is Google anticipated this and built a hard wall for Gemini when it comes to the Work Profile. By default, the AI engine running on the personal side treats the work container as a complete black box. To manage it, you just rely on standard Android Management API parameters. As long as your baseline policy has cross-profile data sharing disabled, your proprietary data is totally sandboxed. On top of that, there’s a new specific device policy payload in Android 16 that explicitly restricts cross-profile AI assistant access, so you can lock it down without affecting the user’s personal side at all.
Did you happen to look at the Android Auto updates they mentioned? We run a fleet of delivery vans, and the devices are basically locked down for navigation and dispatch. The I/O page heavily pushed Auto getting premium entertainment and a smarter Gemini for the dashboard. I absolutely do not want my drivers streaming videos or chatting with the AI while they’re on the clock. Do you know if the native enterprise controls let us strip those out without killing the navigation features?
The consumer side of that update is awesome for road trips, but it’s a total nightmare for managed dedicated devices. Luckily, you won’t have to nuke Android Auto entirely. In the new enterprise APIs, Google is giving us granular controls over the vehicle experience through the Managed App Configurations framework. You just deploy a custom JSON script to the Android Auto system app package. Using standard app config keys, you can set parameters like disable_premium_media and disable_proactive_assistant to true. Your drivers will still get Google Maps and their dispatch apps perfectly mirrored to the dashboard, but all the flashy entertainment and AI rabbit holes are completely blocked out.
