Android tablet locked by Hexnode app password after portal deletionSolved
8 months ago Feb 26, 2026
Hi everyone. I have an Android tablet that was previously managed with Hexnode. The device is currently locked and asking for the Hexnode app password, but the original management portal has been cancelled and deleted, so we no longer have access to it.
Is there a universal default password or an alternative method to retrieve the app password and unlock the tablet without accessing the old portal?
Hello,
Thank you for reaching out to Hexnode Connect!
To answer your question directly: there is no universal or default Hexnode app password that can be used to bypass the lock on an Android device.
The password and restriction settings are tied directly to your specific portal instance. If the managing portal has been deleted or purged, Hexnode can no longer communicate with the tablet or issue remote unlock commands.
In this scenario, the only available recovery option to remove the old Hexnode app lock and restore the tablet is to perform a hard factory reset on the device. Please note that a factory reset will permanently erase all local data, apps, and settings, returning the tablet to its original factory defaults.
I hope this brings clarity to your situation. Please feel free to reach out if you have any further questions!
George
Hexnode UEM.
