Android multi-app kiosk apps not showing until installed firstSolved
4 months ago Jul 10, 2026
I’m setting up a multi-app kiosk on Android devices, but the apps I added to the kiosk policy are not showing on the device once kiosk mode is enabled.
The apps are assigned in the kiosk policy, but some of them were not already installed on the device. I also noticed one app was getting stuck during install, and another two-way radio app was crashing after launch.
Is there a specific order for deploying apps and the multi-app kiosk policy in Hexnode?
Hello @jaxon_r ,
For Android multi-app kiosk, the apps added to the kiosk policy must already be installed on the device before kiosk mode is applied. Adding an app to the kiosk layout does not automatically install it.
Use this deployment order:
  1. Create or use an app installation policy, such as a Required Apps policy, to deploy the required apps to the Android devices.
  2. Make sure the devices are online, unlocked, and able to complete app installation.
  3. Confirm that the apps are visible in the device’s installed applications list.
  4. After the apps are installed successfully, associate the multi-app kiosk policy with the devices.
If the kiosk policy is applied before the apps are installed, the apps may not appear in kiosk mode because they are not present on the device.
In my case, app installation was also getting stuck while the device was already restricted. Does the Play Store need to be allowed somehow for installs or updates?
Yes. If the apps are installed or updated through Managed Google Play, make sure Google Play Store is allowed to run in the background while the device is in kiosk mode.
In the kiosk policy, add Google Play Store to the Background Apps section. This allows app installation and updates to continue without exposing the Play Store to the kiosk user.
However, the recommended approach is still to install all required apps first and then apply the kiosk policy. Keeping Google Play Store in Background Apps helps avoid future installation or update issues after the device is already in kiosk mode.
4 months ago Jul 13, 2026
We had a similar issue with a communication app in kiosk. The app opened but crashed right away because one of its helper packages was blocked by the kiosk restrictions.
That can happen with apps that depend on additional packages or background services.
If an app crashes only after kiosk mode is enabled, check whether the app requires dependent packages, services, or companion components to run. Those dependent packages should be added to the Background Apps section of the kiosk policy as well.
For example, if a two-way radio or communication app depends on additional packages, add each required package separately to the app repository if needed, then include them as background apps in the kiosk policy. This allows the main kiosk app to launch while its required background components continue running.
