I’m setting up a kiosk policy on an Android tablet, but the policy does not seem to apply properly.
The Wi-Fi policy is configured with the correct credentials, and the network is hidden with the hidden SSID option enabled. The tablet is within range because I can exit kiosk mode and connect to the SSID manually, but the Wi-Fi profile is not being applied through the policy.
The same policy also has required background apps, but they only show as available to download instead of installing automatically. Since the tablet is in kiosk mode, that is not practical.
On top of that, every time kiosk mode is enabled, the device shows: “Kiosk activation incomplete: set Hexnode MDM as the default home app to complete kiosk activation.” I set Hexnode as the default home app, but the prompt comes back again the next time kiosk is activated.
This is happening on an Android 11 tablet enrolled using the older generic enrollment method. Other policies in another setup using Android Enterprise seem to work fine. Is this expected behavior with generic enrollment, or is something wrong with the policy?
