This usually happens when an app or service required by the kiosk workflow is not allowed to run. In Android kiosk mode, Hexnode blocks apps outside the permitted kiosk configuration. If a required package launches in the background and is blocked, the device may briefly show the “Access Denied” message and return to the kiosk app, which can look like screen flickering.
If allowlisting is not required for your setup, removing the allowlisting configuration from the policy can prevent these background blocks. However, if you need allowlisting for enterprise app updates, you can keep it enabled and add the required blocked packages as Background Apps.
Recommended steps:
- Reproduce the issue on the kiosk device.
- Run a Scan Device action from Hexnode.
- Open the device in Manage and go to the Applications tab.
- Check the Blocked Packages section for recently blocked package IDs.
- Add the required package to Hexnode using its bundle/package ID.
- Go to Policy > Kiosk Settings > Android Kiosk Lockdown > Background Apps.
- Add the required package under Background Apps and save the policy.
Only packages that are actually needed by the kiosk app or its update workflow should be added as Background Apps. Avoid adding unrelated blocked packages unless they are confirmed dependencies.
