Android kiosk mode not activating after enrollment in HexnodeSolved
2 days ago Nov 11, 2026
We have a couple of Android tablets enrolled in Hexnode where kiosk mode is not activating after enrollment. The Hexnode app and Hexnode Browser get installed, but the tablet still shows all the default apps instead of locking down to kiosk.
I checked the kiosk policy and tried associating the device with the existing policy from Policies > Policy Target, but it still did not work. The device also does not show the expected option to activate kiosk mode after enrollment. Has anyone seen this when the kiosk policy looks correct but the device stays in normal mode?
Hi @oliver_p, Welcome to the Hexnode Community.
If the Hexnode UEM app and Hexnode Browser are installed but Android kiosk mode does not activate, the first thing to confirm is whether the kiosk policy is actually associated with the device and applied successfully.
You can verify this from the Hexnode UEM console:
  1. Go to Policies.
  2. Open the Android kiosk policy.
  3. Go to Policy Targets.
  4. Add the affected device or device group.
  5. Save and associate the policy.
  6. Go to Manage > Devices > > Action History and check whether the kiosk-related actions completed or failed.
If the policy target is correct but the action history shows policy failures, review the other active policies applied to the same device or user. Conflicting Android restrictions, password settings, or user-mapped policies can prevent kiosk activation even when the kiosk configuration itself is correct.
The kiosk policy was already added to the device under Policy Targets. The policy configuration also looks correct. But the device still remains outside kiosk and shows the regular launcher with all apps. Action history shows that one of the policy actions failed.
Hi @oliver_p . I have run into something similar before. In our case, the kiosk policy was fine, but another policy assigned through the user was interfering. Removing and reapplying only the kiosk policy to the device helped us narrow it down.
You are correct @yasmin_farooq , in this scenario, the behavior points to a policy application issue caused by user-based policy mapping rather than an issue with the kiosk app installation.
A useful workaround is to temporarily change the device owner and reapply the kiosk policy:
  1. Create a temporary test user in Hexnode UEM.
  2. Open the affected Android device from Manage > Devices.
  3. Change the device owner from the current user to the test user.
  4. Associate the Android kiosk lockdown policy with the device or test user.
  5. Allow the device to check in and apply the policy.
  6. Activate kiosk mode once the policy applies successfully.
  7. After kiosk mode is active, change the device owner back to the original user.
This refreshes the user-policy mapping and allows the kiosk policy to apply correctly. If multiple devices are affected, repeat the same process for each affected device.
Also make sure there are no conflicting Android restrictions or password policies assigned through the original user, device group, or user group. If such policies are required, apply them carefully after confirming kiosk mode is active.
