All supervised iPhones renamed after using Rename in HexnodeSolved
1 month ago Oct 10, 2026
A colleague was setting up one supervised phone and used the context menu option to rename it. After that, every supervised device ended up with the same device name.
The confirmation message mentioned renaming supervised devices, but it was easy to assume the action applied only to the phone visible in the background. We restored the names, but I’d like to understand how this happened and how to avoid it next time.
Hi @douglas,
In Hexnode, the Rename action for supervised Apple devices can be applied as a bulk action depending on where it is triggered from and what device scope is selected.
If the context menu or action dialog says it will rename supervised devices, it is not limited to the device currently visible in the background. It applies to the supervised devices included in that action scope. This is why multiple supervised devices may receive the same name when the action is confirmed.
To rename only one device:
  1. On the Hexnode UEM portal, open the individual device record for the exact device.
  2. Trigger the Rename action from that device’s actions menu, or ensure only that single device is selected before using a bulk/context action.
  3. Review the confirmation prompt carefully and check whether it refers to a single device or supervised devices in bulk.
  4. Confirm the rename only when the target scope is clear.
This behavior is expected for supervised iOS/iPadOS devices because MDM-based device name changes are supported for supervised devices, and Hexnode can apply the command across the selected supervised-device scope.
