WoundRounds camera not working in iOS multi-app kioskSolved
3 months ago Aug 14, 2026
The camera inside the WoundRounds app would not work on supervised iPhones while a Hexnode multi-app kiosk policy was active. The same app camera worked on a personal iPhone, and it also worked when the managed device was taken out of the kiosk policy. The WoundRounds camera permission under iOS Camera privacy settings was already enabled. Has anyone seen this happen with third-party apps that use the native iOS camera inside kiosk mode?
This can happen when a third-party iOS app opens the native camera interface from within the app.
Many apps use Apple’s native image picker/camera UI. That interface can also reference the Photos library, such as the camera roll thumbnail shown in the corner of the camera screen. If the Photos app is not available in the multi-app kiosk configuration, the in-app camera UI may fail to open or behave unexpectedly.
Check the following:
1. In the Hexnode multi-app kiosk policy, allow the WoundRounds app.
2. Add the iOS Photos app to the same kiosk policy.
3. Make sure the policy is successfully applied to the device.
4. On the device, confirm that WoundRounds has Camera permission enabled under iOS privacy settings.
5. Relaunch WoundRounds and test the in-app camera again.
If the issue occurs only while the kiosk policy is active, allowing Photos in the kiosk is an important step to test.
