Temporarily disable a user-targeted Hexnode policy on a managed deviceSolved
10 months ago Jan 24, 2026
Hi everyone. I need to temporarily disable a policy on a single managed Android device. The policy is currently applied via the user assigned to the device, rather than targeted directly to the device itself.
Is there a clean, temporary way to pause or disassociate that policy for just this one device without deleting the policy? Also, if I remove the user from the policy’s target list, will that affect every other device assigned to that same user? I want to make sure I don’t accidentally drop the policy across multiple devices.
Hello,
Thank you for reaching out to Hexnode Connect!
To answer your question directly: Hexnode does not feature a dedicated “pause” button for policies on individual device pages, so managing temporary disassociation depends on how your policy targets and device-user assignments are structured.
Regarding your question about removing the user target—yes, if you remove a user from the policy targets (Policies > Policy Targets > Users), the policy will stop applying to all devices assigned to that user.
Depending on your setup, here is how you can cleanly handle this:
Scenario 1: The user owns multiple devices (Exclude only one device)
If the user has multiple devices and you only want to stop the policy on one of them, reassign the user on that specific device:
  1. Go to Manage > Devices and select the target device.
  2. Change the associated user to a different user (or unassign the user).
  3. The user-targeted policy will automatically disassociate from that specific device while remaining active on the user’s other devices.
  4. When you are ready to re-enforce the policy, simply reassign the original user back to the device.
Scenario 2: The user only owns that single device
If the user only has that one device assigned to them, removing the user target is the quickest method:
  1. Open the policy in Hexnode and go to Policy Targets > Users.
  2. Remove the user from the list and save the policy.
  3. Once you are ready to resume policy enforcement, simply edit the policy target and add the user back.
I hope this helps you manage your policy targets effectively! Please feel free to reach out if you have any further questions.
George
Hexnode UEM.
