Restricting iOS updates over cellular dataSolved
7 months ago Apr 20, 2026
Hey folks, quick question, is there any way in Hexnode to restrict iOS updates over cellular data?
Replies (6)
I ran into the same requirement recently. From what I checked, there isn’t a direct option to block iOS updates specifically on cellular.
7 months ago Apr 21, 2026
Nothing under restrictions or update policies? Any workaround at all?
Hi @aurora,
Currently, there is no option in Hexnode to restrict iOS system updates over cellular data. As a workaround, you can restrict managed apps from using cellular data through policy configurations. While this won’t prevent iOS updates themselves, it can help reduce overall cellular data consumption on the device. Additionally, you may consider using the OS update deferral option to delay updates, giving you better control over when updates are installed.
7 months ago Apr 22, 2026
Yeah, that’s what we ended up doing too. Between app-level cellular restrictions and update deferral, it’s manageable, though not a complete solution.
7 months ago Apr 23, 2026
Same here. We also informed users to connect to Wi-Fi before updating, which helped in practice.
6 months ago Apr 24, 2026
Thanks everyone for the clarification!
