An extra floating icon started showing on one of our Android devices running kiosk mode through Hexnode. I checked the kiosk launcher settings but couldn’t immediately figure out which option was adding it. Has anyone seen this before?
Hi @jayceon,
This can happen if an Android Accessibility shortcut is enabled for a service on the device. The shortcut may appear as a floating button or icon on top of the kiosk/launcher screen.
To remove it, check the device’s Accessibility settings and disable the shortcut option for the relevant accessibility service:
After disabling the Accessibility shortcut, return to kiosk mode and verify whether the floating icon disappears. If the icon is still visible, also review the launcher settings in the applied kiosk policy to make sure no shortcut or accessibility-related option is enabled there.
