Re-running an automation pushes app installation again to devices with successful statusSolved
8 months ago Mar 26, 2026
Hi everyone. I have an automation configured that deploys required apps to a specific group of devices. I noticed that if I hit “re-run” on the automation, it seems to try installing the apps all over again, even on the devices where the previous automation status was already marked as successful.
Is this expected behavior in Hexnode? I was hoping that re-running it would only retry the devices that failed the first time and automatically skip the ones that already completed successfully. Is there no way to make it skip the successful devices?
5 months ago Jun 26, 2026
Hello,
Yes, this is the expected behavior within the Hexnode portal. When an automation is re-run, Hexnode acts as a blanket re-trigger and pushes the configured action (in this case, the app installation command) again for all devices currently targeted by that automation’s scope.
Currently, there is no built-in option or toggle to automatically exclude devices with a successful status when re-running an automation. It does not act as a “failed-devices-only” retry.
If you need to avoid pushing the app installation commands to devices that already have it, the most practical workaround is to adjust your target scope manually before triggering the action again.
Recommended Workaround:
  • Instead of re-running the original automation against the entire group, identify the specific devices that failed.
  • Temporarily narrow the target list (e.g., by selecting those specific devices manually or moving them into a temporary “Retry” device group).
  • Execute the deployment specifically against that newly defined, smaller scope.
Summary of Re-run Behavior:
  • Re-running targets all devices in the current scope.
  • Devices with a successful status are not skipped automatically.
  • To retry only failed devices, you must manually narrow the target list before running the action again.
I hope this helps clarify how the automation triggers function. If you find any more issues or need further assistance feel free to reach out.
George,
