Hello @liam_t ,
In a private APN deployment, Hexnode UEM does not host the private APN infrastructure. The private APN and its associated network facility are typically provided by your Mobile Network Operator or cellular carrier.
Hexnode UEM acts as the management plane. It pushes configurations such as APN settings, VPN settings, kiosk restrictions, and remote actions to managed devices, but the carrier and your network infrastructure handle the private APN routing.
For VPN gateway placement:
- If you use Hexnode cloud, the VPN gateway should usually be placed in your corporate data center or enterprise cloud environment. It must bridge the carrier’s private APN network with routing that allows the devices to reach the Hexnode cloud service.
- If you use an on-premises Hexnode UEM server, the VPN gateway should be in your corporate network DMZ or another network segment that has direct routing access to the server hosting Hexnode.
In both cases, the devices must be able to communicate with the relevant Hexnode service endpoint. If that route is blocked by the private APN, VPN, firewall, or carrier configuration, MDM commands and real-time actions may not reach the devices.
