Microsoft Teams not showing in Android Enterprise multi-app kioskSolved
4 months ago Jul 21, 2026
I’m trying to add Microsoft Teams to a multi-app kiosk policy on an Android Enterprise-enrolled phone. Teams installs on the device when I use the Install Application action, but when I edit the kiosk policy, I can’t find Microsoft Teams under Local Apps or Public Store.
I also tried approving Teams as a Managed Google Play app and syncing it to the app inventory, but it still didn’t show up in the kiosk app picker. Is there something different I need to do for Teams in Android kiosk mode?
Hello r_foster,
For Android Enterprise devices, Microsoft Teams should first be available in the app repository before it can be added to a kiosk policy.
If Teams does not appear through the usual Managed Google Play search, add it manually using its Android package name:
  1. Go to Apps tab.
  2. Select + Add Apps.
  3. Choose the option to add an app using the Bundle ID.
  4. Add the app with these details:
    • App name: Microsoft Teams
    • Platform: Android
    • Package name: com.microsoft.teams
  5. Add the app.
Then add it to the kiosk policy:
  1. Go to Policies and open the Android kiosk policy.
  2. Navigate to Android Kiosk Lockdown > Multi App.
  3. Add Microsoft Teams from Local Apps.
  4. Save and associate the policy with the required devices.
Also check whether Teams has been added under Background Apps in the same kiosk policy. Apps configured as background apps are meant to run without being shown as launchable kiosk apps. If users need to open Teams from the kiosk screen, remove it from Background Apps and add it under Multi App instead.
Does removing Teams from Background Apps affect other kiosk policies or devices where Teams is already being used? I’m worried it might remove Teams elsewhere.
Removing Microsoft Teams from the Background Apps section of one policy does not edit other policies.
The change applies only to the devices targeted by that specific policy. Teams will remain available in the app repository, and other policies will not be changed unless you manually edit them as well.
