microsoft 365 conditional access sees hexnode-managed kiosk tablets as BYODSolved
10 months ago Jan 18, 2026
We have tablets managed in Hexnode kiosk mode with a few allowed apps. We now need to add an app that uses Microsoft 365 / SSO authentication.
The issue is that our Microsoft Entra Conditional Access policy treats these tablets as personal or BYOD devices and asks for device registration. Since the tablets are already managed by Hexnode, we cannot enroll them into Intune as well.
Is there a supported way to let these devices access Microsoft 365 apps while keeping Hexnode as the mdm and kiosk manager?
Hi @noah-blake,
Because a device cannot be managed by two MDM solutions simultaneously, enrolling these tablets into Intune while they remain managed by Hexnode is not the recommended approach.
Instead, you can configure Hexnode as a compliance partner in Microsoft Intune! This allows Hexnode to continue managing the devices while Microsoft Entra ID receives the compliance status it needs for Conditional Access.
Here is the general setup process:
  1. In the Microsoft Intune admin center, go to Tenant administration > Connectors and tokens > Partner compliance management.
  2. Add Hexnode UEM as a compliance partner.
  3. Select the required platform (such as Android or iOS) and assign the relevant user groups.
  4. In Microsoft Entra ID, open the Conditional Access policy used for the Microsoft 365 app.
  5. Under Grant controls, select Require device to be marked as compliant.
  6. In Hexnode UEM, configure the Microsoft Entra ID integration so Hexnode can send the device compliance status to Microsoft.
With this configuration, the device remains exclusively managed by Hexnode, but Entra ID can evaluate it as compliant for M365 access.
Please let me know if you need any help setting up the integration!
Eden Pierce
10 months ago Jan 19, 2026
Does this require the Microsoft company portal app to enroll the device into intune? That is the part we were trying to avoid because the tablets are locked down in kiosk mode.
Hi @noah-blake,
The Microsoft broker app is still needed for authentication, but it will not take over device management!
For Android devices, you must install the Microsoft Company Portal app. For iOS, you will use Microsoft Authenticator. Because you are using a kiosk setup, you just need to ensure the required Microsoft broker app is added to your kiosk policy as a background app (or allowlisted) so it can function during SSO authentication.
The broker app simply acts as the authentication bridge for Microsoft sign-in. Hexnode remains your sole MDM, and Intune receives the compliance signal via the partner integration rather than through direct device enrollment.
Please let me know if you run into any issues adding the broker app to your kiosk policy!
Eden Pierce
