MaintainX uploads fail on Android kiosks due to SSL inspectionSolved
4 months ago Aug 04, 2026
We have Android devices running in kiosk mode through Hexnode. The MaintainX app works normally, but uploads fail at one site with a message similar to “Can’t upload from this network.”
The app vendor asked us to allow and bypass SSL inspection for the upload backend domain used by the app. These are standard Android devices, not Samsung Knox devices. I also could not find any Global HTTP Proxy configuration in the Hexnode policy.
Has anyone handled this through Hexnode, or is this something that needs to be fixed on the network side?
Hello @ryker ,
This behavior usually points to a network-side firewall, proxy, or secure web gateway performing SSL inspection on HTTPS traffic.
For apps that upload files to cloud storage endpoints, SSL inspection can break the trusted secure connection. The app may then reject the upload and show an error such as “Can’t upload from this network.”
A quick way to confirm the source of the issue is to connect one affected kiosk to a completely different unrestricted network, such as a mobile hotspot:
  • If uploads work on the hotspot, Hexnode UEM kiosk restrictions and the app configuration are not blocking the upload.
  • If uploads fail on the hotspot as well, then a device restriction, app configuration, or policy setting may need to be reviewed.
If the devices are not using a Global HTTP Proxy deployed through Hexnode UEM, there is no proxy exception to configure in Hexnode. In that case, the required fix is for the network administrator to add the app’s upload/backend domain to the SSL inspection bypass or allowlist on the corporate firewall or secure web gateway.
