macOS ADE device shows partial success for restrictions when hidden admin account is not logged inSolved
5 months ago Jun 30, 2026
We’re testing a newer macOS ADE enrollment workflow where a hidden local IT admin account is created during setup. The employee then creates/logs in with their own local user account.
The Mac is checking in now, but in the policy Action History I’m seeing a partial success/warning under a restrictions policy. This made me concerned because we previously had a Mac stop checking in after a couple of days and ended up wiping it.
Is this warning caused by the hidden admin account not being logged in? Could it affect Hexnode check-ins or prevent the policy from applying to the employee’s actual user account?
Hi @noah-blake,
For macOS ADE enrollments with a hidden local admin account, this type of warning can appear when the policy contains user-level configurations.
Hexnode policy behavior on macOS can be understood in two parts:
– Device-based policy payloads apply globally to the Mac, regardless of which user is logged in.
– User-based policy payloads apply only when Hexnode can associate them with an active user session on the device.
If the hidden IT admin account is created during ADE but is not logged in, user-level configurations may temporarily show a warning or partial success in Action History because that account does not have an active session.
This does not mean the Mac has stopped checking in, and it does not require the hidden admin account to be made visible or used by the employee. Once the employee logs in with their actual account, Hexnode evaluates the active user session during routine check-ins and applies the applicable user-level payloads to that profile.
You do not need to disable the hidden admin account or change the ADE workflow if the device is otherwise checking in normally.
