Broadening our integration capabilities, the new IdP Connector allows you to bring your preferred custom Identity Provider directly into Hexnode UEM. By supporting standard protocols like SAML and OpenID Connect, this feature lets you seamlessly connect to any identity platform to authenticate and manage your users.
What’s new?
- Streamlined setup and AI blueprints: Enter your provider’s name to instantly auto fill standard SSO fields, then simply plug in your unique credentials. For directory sync, our built-in AI blueprint provides tailored step-by-step instructions to help you easily configure all the necessary credentials and permissions.
- Flexible provisioning methods: You have total control over how your user data flows into Hexnode UEM. The connector offers multiple provisioning options to suit your workflow, including Automated REST API Sync, Just In Time Provisioning, and SSO Only. These methods support a wide variety of directory management scenarios, ranging from continuous background updates and instant user creation to basic authentication.
- Custom attribute mapping: Keep your data perfectly organized. The setup flow features a dedicated mapping screen that lets you link specific fields from your custom provider directly to the corresponding user and group attributes inside Hexnode.
To get started, navigate to Admin > Integrations > Available Integrations > Identity & Access Management (IAM/IdP) > IdP Connector in your Hexnode UEM portal and integrate your custom Identity Provider.
