How to check if Hexnode MSI installed on a Windows PCSolved
1 month ago Oct 20, 2026
A Windows user received an MSI that appeared to be a Hexnode installer. The install did not seem to complete, and Windows showed code 1602 during the attempt. There is no obvious Hexnode entry in Programs, but I want to confirm whether the device was enrolled or whether any Hexnode agent was installed. Does Hexnode appear under a different name like MSP Agent or RMM Agent, and where should I check for installer logs?
Hi @gnishilda,
Hexnode typically appears under the name Hexnode on Windows devices.
To verify whether the Hexnode agent was installed or whether the device was enrolled, check the following:
  1. On your Windows device, open Settings > Accounts > Access work or school.
  2. Confirm whether any work or school account related to Hexnode or your organization is listed.
  3. Open Installed apps or Programs and Features and check whether Hexnode is listed.
  4. If installer logs were generated, check whether a folder exists at C:\hexnodeinstaller.
Hexnode should not normally appear as MSP Agent or RMM Agent in the installed apps list. The expected application name is Hexnode. If there is no Hexnode app listed, no related work or school account, and no installer log folder at C:\hexnodeinstaller, the installation likely did not complete and the device does not appear to be enrolled through that installer.
